latest vdj 8 public build, on a macbook pro im now getting static sound when scratching slowly.
video proof for your listening pleasure
https://www.dropbox.com/s/du1fxlh88x1219d/static%20VDJ8.mov?dl=0
geposted Mon 08 Sep 14 @ 6:36 pm
Yes we are aware of this. Hopefully it will be addressed in next builds.
Btw, does this sound goes away or improved if a different Latency is chosen ? E.g. a lower or a higher one ? Which sound card/controller are you using ?
geposted Mon 08 Sep 14 @ 6:41 pm
i used the sound-card from the mixtrack pro (v1) and also tried the pioneer wego 2. my latency is set to automatic, what number should i try? btw i tried thru the internal card (plays out of the computer speaker same static regardless.) mouse and keyboard only
geposted Mon 08 Sep 14 @ 6:49 pm
i regressed back to build 1932, static is all gone. was driving me nuts. ill stick w this build until its ironed out.
geposted Mon 08 Sep 14 @ 7:17 pm
I have this too, with slow scratching. Not as loud as yours though.
geposted Fri 12 Sep 14 @ 12:34 am
Sounds like there's a fly behind the screen!
geposted Fri 12 Sep 14 @ 12:46 pm
I also have this problem using the stanton scs1d.
looking forward
looking forward
geposted Fri 12 Sep 14 @ 1:15 pm
i went back to build 1932 solved the problem for the moment.
geposted Sun 14 Sep 14 @ 10:48 pm
