Forum: VirtualDJ Skins
Topic: Sampler line
WWDJdkPRO InfinityMember since 2008
If i wanted a field, like the one where the time shows on the basic skin, but only showing the selected sample instead, what code should i make?
It should work, so when i scroll through my samples it shows the sample name...
geposted Thu 11 Sep 14 @ 5:48 pm
FruitPRO InfinityMember since 2003
[delete]
geposted Thu 11 Sep 14 @ 7:12 pm
no one knows this ?
geposted Mon 15 Sep 14 @ 7:41 am
Can you explain in more detail?
geposted Mon 15 Sep 14 @ 3:35 pm
@ djppdkk mock up a picture in paint because I don't think anyone understands what you want.
geposted Tue 16 Sep 14 @ 7:14 am
I want a field where the name of the sample (wich is in focus) is shown.
So when i use my encoder on my controller to scroll through the samples, the name of the sample changes in the field, to the one that is selected.
Just like the field you have with FX, where it says : "Backspin" and when you move on to the next one it shows "Beatgrid"....
I dont need it to be able to activate the effect, cause my mapping already does that.. just show the name of the sample
geposted Tue 16 Sep 14 @ 2:19 pm
like this
geposted Tue 16 Sep 14 @ 2:25 pm
like this
get_sample_name 0
geposted Tue 16 Sep 14 @ 2:59 pm
So the code sould look like this ?
<!-- drop down -->
<button class="sampler_name" action="sampler_active">
<pos x="+150" y="+0"/>
<text action="get_sampler_name 0"/>
</button>
<button class="sampler_select" action="sampler_select">
<pos x="+147+107" y="+0"/>
</button>
geposted Tue 16 Sep 14 @ 3:58 pm
dont work...
You didn't spell it correctly.
You did put a "R" in "sampleR" where the word is "samplE".
Otherwise your above code should work flawlessly.
geposted Tue 16 Sep 14 @ 4:04 pm
Got it... thanks
geposted Tue 16 Sep 14 @ 4:23 pm
Can you actually play the sample like that?
geposted Tue 16 Sep 14 @ 6:55 pm
