- new timecodePitchDelay option
- small fixes to the timecode engine
geposted Fri 12 Sep 14 @ 4:47 am
my vdj does not working now, it won't install BUILD 1960..please help !!
geposted Fri 12 Sep 14 @ 5:10 am
After VDJ 1957.804 the software had been updated to 1959.804.
When I restart VDJ following windows appears:
After clicking yes this windows disappear and reappear again and again. When I close it VDJ 1959.804 opens.
Therefore it is not possible to upgrade to never version 1960.
geposted Fri 12 Sep 14 @ 5:24 am
i had an update loop so i dl the zip from here
https://virtualdj.com/download/virtualdj8/pc/1960/zip
installed it and it contains 1959 not 1960
also they forgot the 8 in the files name
geposted Fri 12 Sep 14 @ 5:36 am
Same problem here
geposted Fri 12 Sep 14 @ 5:40 am
I am also stuck in this cycle. I was running 1959 but it now will not update to 1960.
The popup appears but clicking 'yes' does not apply the update (and the ChangeLog displayed for 1960 is blank).
geposted Fri 12 Sep 14 @ 5:49 am
Same here, manually restarting vdj puts you in the same loop
geposted Fri 12 Sep 14 @ 6:51 am
Same here
geposted Fri 12 Sep 14 @ 7:18 am
yes, there's been a glitch in the update process.
Should be fixed now.
geposted Fri 12 Sep 14 @ 7:19 am
No ........ Still happening here (1959.804) Win 8.1 AMD FX-8350 16GB
geposted Fri 12 Sep 14 @ 7:35 am
Updated this morning , seems to be fine for me . Windows 7 64bit
geposted Fri 12 Sep 14 @ 7:39 am
Try deleting the .ready file in docs/vdj/cache
After doing that, I am now updated to 1960 - although the 1960 ChangeLog still shows nothing.
geposted Fri 12 Sep 14 @ 7:43 am
Can not close application .. followed by a crash . Otherwise it works .
(close solved)
(close solved)
not updating either, also win 8.1
geposted Fri 12 Sep 14 @ 7:44 am
Thank you it works for me.
geposted Fri 12 Sep 14 @ 7:49 am
Cheers Groovin', updates perfectly now, changelog still blank tho' :-)
geposted Fri 12 Sep 14 @ 7:52 am
I feel that dev Team is working so hard and with a lot of pressure.
Thanks
Thanks
So what's up wit the boot loop
Thanks groov Deleting Ready File worked
geposted Fri 12 Sep 14 @ 8:01 am
Update Error:Keep On the Version 1959.804 System:Windows 8.1 Enterprise GPU:AMD Radeon 7700 RAM:8G HardDisk:seagete
geposted Fri 12 Sep 14 @ 8:03 am
Very Red hahaha......
geposted Fri 12 Sep 14 @ 8:04 am
