I select the effects to show on each deck (Phaser, echo, etc). I then close the software and my selections are not saved. I have to reselect which ones I want to show every time I open VDJ.
Bug?
Bug?
geposted Mon 15 Sep 14 @ 9:43 am
Platform,
Which decks?
Decks 3 & 4 is a known issue
Which decks?
geposted Mon 15 Sep 14 @ 9:54 am
Decks one and two.
Mac
Mac
geposted Mon 15 Sep 14 @ 10:35 am
Most likely you use a controller that has some knob(s) assigned as "effect select"
When the controller initializes it reports the position of your knobs and therefore the selected effects change
geposted Mon 15 Sep 14 @ 11:25 am
