i have a Mac with vdj8 and the DDJ-SX every time i load a song i have to turn the trim all the way up then down b4 it will work right why is that
geposted Thu 18 Sep 14 @ 4:39 pm
This is called soft-takeover. Read more here.. https://virtualdj.com/wiki/Soft%20Take-over%20or%20Non-MIDI%20Mixer.html
geposted Thu 18 Sep 14 @ 8:22 pm
If I disable soft take over will it mess with anything else or should I just leave it alone
geposted Thu 18 Sep 14 @ 9:06 pm
You can disable it from the Options (ControllerTakeOverMode to Instant or Gradual), but i would strongly recommend you not to. It could cause sudden changes to Volume, EQ etc.
geposted Fri 19 Sep 14 @ 7:48 pm
