Forum: Addons
Addons comments
Topic: Effect Pack 8
leneerPRO InfinityModeratorMember since 2014
geposted Thu 18 Sep 14 @ 4:54 pm
hey I installed the effect pack and vdj8 wont read is there any trick to the installation please reply thanks, I was doing drag and drop to one deck and it gave me error thanks
geposted Thu 23 Oct 14 @ 9:48 pm
Shows the headline but not the effects...
geposted Fri 24 Oct 14 @ 12:45 am
D/L the mac vers: title but no effects
geposted Sat 08 Nov 14 @ 9:01 am
Guess I should of read the comments First! Same issue, it won't play the effects. Really want that wolf whistle!
geposted Fri 21 Nov 14 @ 4:23 pm
Just figured the above problem out. I'm new to this so you will have to forgive me if my terms aren't technically correct, but if you go under the "sampler" folder in the far left column, then it will display all the downloaded effects/packs. You then have to manually drag and drop the effects into the "Effects Column" (where they should be). Also I had to save the pack first and then run it. Hope this helps.
geposted Sat 22 Nov 14 @ 2:42 pm
GOOOD LOOKIN OUT!!!!!!!!!!!
geposted Thu 07 May 15 @ 10:39 pm
Does anyone know how the make them read in English?
geposted Tue 12 May 15 @ 11:22 pm
how to mix song
geposted Tue 10 Jan 17 @ 8:12 am
Jsand777PRO SubscriberMember since 2016
THX but where is the affects folder Located?
geposted Sun 29 Jan 17 @ 10:18 pm
Is it possible to have the tags in english?
geposted Sat 19 Aug 17 @ 2:19 pm
\Documents\VirtualDJ\Sampler
had me thinking they were effects but they are sound effects...stupid me...lol
geposted Sat 19 Aug 17 @ 9:32 pm
miontyHome userMember since 2018
hi guys does virtual dj have a plugin like loop delay or a plugin to make the loop sound better.Please help thanks
geposted Fri 06 Apr 18 @ 10:08 am
ciao come si scaricano ?
geposted Fri 21 Dec 18 @ 4:21 pm
Please post in English (or use the appropriate forum for your country).
You can download this pack once you have a VDJ license.
geposted Fri 21 Dec 18 @ 5:40 pm
pack
geposted Fri 08 Nov 19 @ 11:13 pm
