Forum: Addons
Topic: Speech Pack 8
leneerPRO InfinityModeratorMember since 2014
geposted Fri 19 Sep 14 @ 12:10 am
this doesnt work!
geposted Sat 20 Sep 14 @ 3:14 pm
MacBook Pro, file downloads, unzips and installs successfully, the samples aren't showing up in the Sample Bank, just the headline....
geposted Fri 24 Oct 14 @ 12:50 am
i did some adjustment and its worked
geposted Fri 14 Nov 14 @ 8:31 pm
what where your adjustment's because i downloaded it today and it does not show up. this is on pc.
geposted Sat 15 Nov 14 @ 2:02 pm
joubejoPRO InfinityMember since 2008
the samples do not show up at the trigger pad - anyone have the work around?
geposted Sun 07 Dec 14 @ 6:59 am
What is speech pack? there is no description!
geposted Tue 09 Dec 14 @ 2:13 am
unzip then place the folder in the Sampler Folder
geposted Sat 03 Jan 15 @ 10:22 pm
keoni4uPRO InfinityMember since 2005
are there any English versions? how do you go about editing them?
geposted Sat 13 Jun 15 @ 7:44 pm
you can edit the title as well
geposted Fri 31 Jul 15 @ 5:02 pm
I just wonder, is there aders styl of Air Horn and siren in side here.
geposted Fri 12 Feb 16 @ 11:43 am
They're all the same.
geposted Mon 15 Oct 18 @ 12:57 am
