Forum: Old versions
Topic: Auto fade music when mic is pressed
Hello everyone,
Can anyone tell me how to do what i said in the title so when i press my mic, the music will fade to about 50% volume
Cheers
geposted Fri 19 Sep 14 @ 10:26 am
How fast a fade? and you mean the mic button on the skin right?
*edit* whatever button you mean be it skin or controller, a script something like this might do, (It's a press and hold for 1 second script)
mic & repeat 50ms & level 50% ? nothing : level -2.5%
when you press the 'mic' button on the skin layout, and a fairly fast fade
Check post above
That will fade smooth in 1 second
To get it to work in with the skin press needs either a custom button or some skin editing.
you've confused me, can you do like a step by step guide please, im new
Ok I'll step by step it, what skin are you using?
VirtualDJ 7 (2 decks): 1280x768
eugh V7 erm It can be done but it's too complicated to explain to a beginner
Just set up a keyboard key script with this key.
im not on VDJ 8, i have 7
Edit: didnt see above, lol
step by step to do this:
so noob, i know
got ya, cheers
