Forum: Old versions
Topic: Some Help please
So i buy from a person one midi controler Koolsound,sound mix station so the problem is the drivers,can some one give me the drivers,
Thx a lot
geposted Fri 19 Sep 14 @ 5:26 pm
You don't need to post the same thing three times (so far). Once is enough.
This is the Atomix web site. Support here is for Virtual DJ. For Kool Sound products, you need to go to their web site.
The person you bought it from should have supplied you with everything. Ask them!
Finally, are you sure that the product needs a driver? Generally, budget units like that are class compliant - no driver required.
so i instaled,the virtual dj on my laptop and the i connect the midi controler so,in the virtual dj is not reconized
