Forum: Old versions
Topic: Song length issues
When i drag a song onto the decks that about 3 mins long, it says theres 10-20 mins remaining and when the actual end happens, nothing happens as it says 15 mins remaining. Help anyone?
Cheers
geposted Sat 20 Sep 14 @ 5:27 am
What file type is it, and how is it encoded? Is it VBR by any chance?
its an mp3 file
the VBR header is corrupted and until VDJ scans it fully it will read wrong.
only app i know that fixes corrupt headers is foobar 2000 its a media player easy to find with a Google search if u decide u need to fix the headers.
tutorial?
only one i could find it should be good its simple to do
thewobblingmind.wordpress.com/2007/09/15/fixing-track-duration-length-of-mp3-foobar2000/
All you have to do is:
Right click the “corrupted” track in question in your foobar2k player
Select Utils
Choose “Fix VBR MP3 header”
That’s all to fix the track duration length!
i did that to all my files and i still does the same in VDJ
then it must be something with vdj i recommend you scan all your files and it should go away
