Having some issues with version 8, My saved playlist always use to save in the order that I put them in on version 7 but now in version 8 they save in alphabetical order!
This really messes me up. I have them in a certain order on purpose. Can this be changes in settings or can this be fixed for version 8?
Also having some issues with saved playlists after reopening version 8 that the playlist music loses its connection to the file.
This really sucks when I take the time to make the playlists and get to a gig and have to redo all the work!
Also noticed a few times that the song is in my search but errors when I try to load it. Then when I look at the file location it show my documents.....
All my music is on an external usb hard drive.
geposted Sat 20 Sep 14 @ 12:25 pm
Playlist sorting right click any field header, at the very top of the context menu theres the option, Rest Sort Order click it.
The tracks that error are usually missing tracks. right click one and relocate or just do a database clean up.
geposted Sat 20 Sep 14 @ 12:35 pm
