Forum: VirtualDJ Skins
Topic: VDJ 8 Mac - rhythm vs rhythmzone
Hi
Based on evidence from recent posts & feedback, I am wondering if VDJ 8 has an issue with skins using the old <rhythm> code for displaying the large waveforms on Mac?
One Pro user recently posted pics of a VDJ 7 skin from his Mac and it showed a solid block of colour instead of a waveform on the strip across the top of the skin.
Another user has stated that the waveform "does not show" on his Mac when using my updated Mix Lab skin.
Both these skins use <rhythm> and not the new <rhythmzone> code. Is this the cause? Using <rhythm> works fine on PC, and I have no Mac for testing.
geposted Sun 21 Sep 14 @ 4:51 am
FruitPRO InfinityMember since 2003
Converting <rhythm/> to <rhythmzone/> is not that hard as it doesn't require extra graphic work.
Simply add colors in the header and replace the name of the element. You may have to get rid of some of it's tags too.
Dunno if there's a known (or not) issue... And I have no mac to test it either.
geposted Sun 21 Sep 14 @ 7:58 am
