Forum: Beta Builds Regression Bugs
Topic: BUILD 1970 - Page: 2
@Sclavel
Some users are reporting pitch fluctuations at the beginning of tracks when using time codes. Personally I have no such issues but could you please take a look into this thanks
Mac Itunes is totally broken in this build and possibly the build before that. What happens is Virtualdj thinks the tracks are missing when they are not really missing they will even load to the deck. The problem is Virtualdj will not read the tags to these files. I've checked the paths and its correct. I've even tried a new library the result is the same.
.I just move the Mouse across the wave form with 2 songs in decks ( Crash ) & Using Content Unlimited (Music ) when Download the track and Eject it from the deck VDJ will freeze & lock up got to forced to quit when lock up
static/popin noise when dragging Slow or scratching Very Very slow... & also When you do a back BackSpin on the JogWheel on the controller,VDJ-8 Crashes.(OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM & RMX II )
