Topic: REQUEST FOR CLASSIC PITCHBEND SOUND
HELLO FELLOW MUSICIANS AND ALIKE. THIS IS MY FIFTH INQUIRY ON THIS SUBJECT.
I'M PASSIONATE ABOUT VIRTUAL DJ, WHICH IS WHY I WILL NOT GIVE UP!
WE CURRENTLY DO N0T HAVE A " CLASSIC PITCHBEND " SOUND.
DOE'S THIS NOT BOTHER ANYBODY?
WE ARE CURRENTLY UNABLE TO PITCHBEND AS WE WOULD IN VIRTUAL DJ 7 OR IN HARDWARE TURNTABLES .
THIS IS MESSING UP MY VIBE! PLEASE HELP ME CONVINCE THE DEVELOPERS TO PROMPTLY ADD THIS FEATURE.
I PITCHBEND DURING MY MIXING TO ACHIEVE DYNAMICS. ITS VERY OLD SCHOOL BUT SOUNDS GREAT! I NEED IT ON MY VIRTUAL DJ 8 COME ON! PLEASE!
geposted Mon 22 Sep 14 @ 10:28 pm
+1 seems pitch bend now have master tempo forced.
I tried disabling master tempo in both decks, but the issue persist.
Thats true how can disable this? Master tempo
@i1111
That's no reason to shout to us !!! (CapsLock activated = shouting)
Do you want to pitch, so that the song sounds higher or lower in key ?
Then you have to disable "Key lock".
@espepe
You can disable master tempo in the config - options - master Tempo. Set this to "No".
dj ragman thanks for your post, no i wasn't shouting, sorry for the caps if it offended you!
The truth is i'm an expert with virtual dj in general. Been using it since version 5.
Sorry to say if you can't realize we have no true pitchbend sound while pitchbending a controller jogwheel then you are not on the level.
if anyone comes up with solutions or would like to continue requesting to the developers to fix this, please unite and lets get our Virtual DJ 8 up to speed! thanks
1 1 1 1
Eleven ELeven
djragman wrote :
@i1111
@espepe
Hi can you show me where to disable key lock, I can't see in the settings
key lock maybe disabled but you will not get a classic pitchbend sound with turning the jogwheel
You keep calling it a "classic" sound - but why would you actually want the pitch to go off when you pitch bend???
Surely that's a bad thing. Something which was unfortunate but inevitable and unavoidable in the past, but now it doesn't need to happen.
Seriously, you want your mixing to go off key?
