How about a command (assignable to a shortcut) that transfers the inactive tunes bpm to the active tunes bpm....
Cheers
Dan
Cheers
Dan
geposted Mon 29 Sep 03 @ 6:13 pm
Just make the inactive deck active (backspace), push mach button and then swich active/inactive again.
geposted Tue 30 Sep 03 @ 7:07 am
Also, I'm not sure it will work, but you can try to assign a key to both sortcuts ("select on default desk" and mach).
geposted Tue 30 Sep 03 @ 7:11 am
nscode - you misunderstand what i am saying - not mach but transfers ie you have a tune with correctly calculated 170 bpm, the other new tune has incorrectly calculated bpm so you mach it manually, what i would like is button to bring the 170bpm over to mannaully mached tune, although its actual bpm will not be that becuase you have pitch shifted it......
geposted Wed 08 Oct 03 @ 12:22 pm
