Forum: Addons
Topic: Loop Out - Page: 1
Discussion about Loop Out
v1.1 - Added 1/8 loop size option
geposted Wed 24 Sep 14 @ 3:58 pm
This is awesome as it also effects the video aswell, hell yeah!!
Might I make one small suggestion.........As the loop fades could we also have the video as well please??
Eitherway its another great plugin!! Thank You!
geposted Wed 24 Sep 14 @ 7:21 pm
The only problem with that is that once the plugin deactivates - ie after the loopout is completed - the video will once again be visible as the plugin will no longer have control.
Is that acceptable?
geposted Wed 24 Sep 14 @ 7:42 pm
That'll work for me sir!! I'm usually cross fading anyways so it'll be perfect for my needs.
Thank you!!
geposted Thu 25 Sep 14 @ 12:28 pm
ahh, nice :)
geposted Thu 25 Sep 14 @ 1:35 pm
How about a button option to unload the deck upon completion? (for the video deck bug)
I'll guess this (plugin generally) is the same sort of coding that'll be used for the script sequencer, 2 plugins in one week is a very promising sign.
geposted Thu 25 Sep 14 @ 6:56 pm
GREAT effect!!!!
geposted Thu 25 Sep 14 @ 11:17 pm
geposted Fri 26 Sep 14 @ 9:52 am
Small request........
Would it be possible to add a key up or down on the echo?? I know we used to have one that did that.
If possible make it an option that can be turned on/off.....
geposted Fri 03 Oct 14 @ 5:04 pm
Awesome! I have my loop out back. Quick question, how do I reset the effect's parameters?
geposted Sun 19 Oct 14 @ 8:19 pm
thx so much ! this is what i need !
geposted Sat 25 Oct 14 @ 7:04 am
AsTheDJPRO InfinityMember since 2008
What Up Dj'sss On Loop Out I can play 2 different song deck 1 and deck 2,I loop out deck 1 then clone deck 2 to 1before it's stop the loop out cause VDJ-8 crash/freeze and NO sound b4 it goes/play in deck 1..OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
geposted Tue 28 Oct 14 @ 8:43 pm
Doesn't crash VDJ here, but you're right there is sometimes no sound - but that's because the effect is still active and you've bypassed the effect disabling itself by cloning to the deck. If you turn the effect off then the sound comes back.
I may put a catch in for that at a later date whereby if the track changes the effect auto deactivates.
Why would clone to a deck with loop out active on it though, that seems a bit, well, strange?
geposted Tue 28 Oct 14 @ 8:57 pm
when the 1st goes off then I clone the song is playing ,then I can double mix it on the fly.
geposted Wed 29 Oct 14 @ 9:11 pm
hey is there any way that it will set the loop back to 4 beats I use the loop out at 1 beat but when is disable I would like to set the auto loop at 4 beats sometimes I forget to set the loop at 4 beats and when I use the auto loop and instead of giving me four beat auto loop it gives me 1 beat auto loop because it was set at one beat by the loop out effect
geposted Sun 02 Nov 14 @ 8:07 pm
geposted Tue 04 Nov 14 @ 12:02 pm
I just got a DDj-sx-2 & it has now a roll on the pad so I just use that for right now thanks..
geposted Tue 18 Nov 14 @ 1:24 pm
If I hit loop out ( set up 17 loop ) and I pulse the song,then drag a 2nd song in the deck were the pulse track is it will lock up... Mac O/s
geposted Sun 04 Jan 15 @ 12:49 pm
Same here it loop out makes vdj8 to crash after latest update of vdj
geposted Thu 15 Jan 15 @ 10:05 pm
Plugin updated to v1.2 to fix a crash/freeze issue.
geposted Tue 17 Feb 15 @ 2:24 pm
51%
