vdj 8 on macbook pro. when i have a song loaded to play from beginning if im scratching and hit play it has a slight 2 sec lag. if i hit play and immediately start to scratch it wont even play. slight lag wait 1 sec and boom i can scratch.
tried on vdj7 works perfect. can people please post what they have for scratch settings?
geposted Wed 24 Sep 14 @ 5:32 pm
turn MotorWheelInstantPlay On and MotorwheelLockTime 0.2 , I also use StartRamp 0.2 to avoid that "jump start", but it still happens if I start the track(motorwheel off) using the HotCues, the Cue button or if I clone a deck with the platter stopped/not rotating, to workaround this is turning MotorWheelInstant Off but then I can't hold the platter and hit play...
geposted Thu 25 Sep 14 @ 6:41 am
ok , ill try those settings! Thanks for the tips
geposted Thu 25 Sep 14 @ 3:06 pm
*UPDATE*
just wanted to give you a heads up, those settings worked pretty good. still not as smooth as VDJ 7 but pretty damn close! THANKS AGAIN!!!!
geposted Fri 26 Sep 14 @ 4:27 pm
