Topic: Videos freeze in automixDualDeck
Hi, when I load some videos in the automix in automixDualDeck mode, after the first 2 videos have played, the 3rd one doesn't show the video but the audio is loading properly. It came back with a frozen image of the first video that was loaded at the first instance on this deck... If I reset the master output (CTRL-V twice) the video is playing properly but the same "bug" is coming back on the next videos... This is not the case when the automixDualDeck is not activated... is it something that was already reported?
geposted Wed 24 Sep 14 @ 6:12 pm
Same problem here. Video-Automix runs only in One Deck Mode at the moment.
Will be fixed in the next build
Great! Thank you very much.
Excellent! Thank you!
hi i know this post is a long time ago, but when i start auto mix the music stop when the next song comes only for 2 second. the music is from external hard drive, im using mac and windows 8 tnks for all.
