Win 1973
I'm sure you could drag effects into folders/groupings from the effect drop down menu. But I've just helped someone who asked about this and I tried myself (first time in months) And I couldn't,
I'm more than convinced that I have done in the past. Could some one confirm that this was the case just for my sanity?
geposted Fri 26 Sep 14 @ 12:25 pm
Should work indeed. Keep in mind that it is only possible for installed effects, not for the built-in native effects.
geposted Sat 27 Sep 14 @ 10:17 am
It doesn't and I'm talking about 3rd party VST's
The move icon (little square) shows up but they don't move.
geposted Sat 27 Sep 14 @ 11:46 am
Tested and working OK here for non built-in VDJ effects and VSTs. I can move them in and out of folders :)
geposted Sat 27 Sep 14 @ 7:16 pm
Thanks for the reply Scott,
I'll have a poke around in windows maybe there's a permission or something stopping me or maybe I'm not getting it quite right.
False alarm folks, Move along.
Lock the tread
Lock the tread
geposted Sat 27 Sep 14 @ 7:35 pm
Does that mean it's working for you now?
geposted Sat 27 Sep 14 @ 9:36 pm
Apologies, USER ERROR, If you drag FX into group/folder header it will move, but if you drag it into a open(expanded) group it doesn't move.
geposted Sat 27 Sep 14 @ 9:49 pm
