findng that the gain buttons are sticking and the only way to get them to respond is by turning the controller knobs up until the program responds ....thus causing a massive surge in volume until i turn them back down again ..... thinking of going back to 7 until the issue is fixed ...although fair play the new interface is beltin
geposted Sun 28 Sep 14 @ 2:37 am
This behavior is actually a feature. Please see here.. http://www.virtualdj.com/wiki/Soft%20Take-over%20or%20Non-MIDI%20Mixer.html
geposted Mon 29 Sep 14 @ 3:11 am
VirtualDJ 8 has a new and advanced controller Take-over mode called "gradual" but it is not the default mode.
Go to : Settings > Options > Search for controllerTakeover ..
Set to gradual and see if you like it more., we would like to hear your feedback.
"The gradual option will gradually move the software knob/slider position back to the hardware knob/slider position as you move it. This means that you can immediately make adjustments and the two will eventually catch up and synchronise with each other."
geposted Mon 29 Sep 14 @ 4:20 pm
when I Get started running VDJ on MAC the dialog of recommend to gradeup Pro-ver appear after that,
I less able to operate connected the equipment(xdj-r1).
Do I have to change settings or re-installing vdj?
geposted Sun 05 Oct 14 @ 7:14 am
