I wanted to find out when Midi Clock will be added back into VDJ 8, I am sure that I am not the only one waiting for this to be added back in... Not having this ability is the only thing that is keeping me from using this live, as I am not experiencing issues with the software or my controller. Now with that said I may not use all the functions or hardware everyone else uses, but I am not having any problems and would like to take it out for a spin live, but need the midi clock added back in so that I can have the software communicate with my other software I use. Please let me know when the ETA for Midi Clock will be added in.
Thank you
Thank you
geposted Mon 29 Sep 14 @ 10:44 am
+1 and an even BIGGER +1 for it to be on the Mac side as well.....
geposted Mon 29 Sep 14 @ 12:58 pm
I'm not sure lads but would this do it?
http://www.kvraudio.com/product/clocker_by_expert_sleepers/details
geposted Mon 29 Sep 14 @ 5:19 pm
nice find loco i bet that would work for most people
installed it and gave it a run on the master seems to work ok it didn't crash vdj8, granted i don't have any external midi devices to test it with at home maybe someone can try it out that does and see how it goes.
geposted Mon 29 Sep 14 @ 7:54 pm
The mate I will test it tomorrow with my lighting software and report back....
geposted Mon 29 Sep 14 @ 9:12 pm
Hey WickedMix how did you install it so that it read the info from VDJ8?
geposted Mon 29 Sep 14 @ 10:04 pm
Literally take
clocker.dll and put it into a folder, C:\Users\YourPCName\Documents\VirtualDJ\Plugins\SoundEffect\erm
refresh the list inside V8 and there you go. Turn the fx on
The problem is it doesn't read the info from V8, it's a manual set.
geposted Tue 30 Sep 14 @ 4:18 am
A spot of Googling later...
http://wavesum.net/products.html#waveclock
geposted Tue 30 Sep 14 @ 4:30 am
Yeah Groovin that's what I've used before and it's pretty good but if I remember right I had some kind of midi conflict when using it on my Mac.
Just wish they'd add it and do it right this time........ Hopefully the wait won't be that long. 👍
geposted Tue 30 Sep 14 @ 10:09 am
Yeah my thoughts exactly... I do not know why it just cannot be added back in... They have ever intent based on their past comments but I guess they are waiting to solve all the problems first which is pretty much holding those people with no issues hostage. I guess I will just have to use the audio analyzer that came with my other software until this is fixed, but I am not happy because it is just not the same, or continue using VDJ 7....
The lack of response on their part also does not say a lot either...
geposted Tue 30 Sep 14 @ 1:49 pm
I hope this gets added soon.
geposted Thu 02 Oct 14 @ 2:34 pm
I just found this on the interwebs.
None other than Adion himself made a VST plugin that generates a MIDI clock from audio, back in 2007.
So it begs the question, why hasn't VDJ 8 got this built in?
geposted Fri 10 Oct 14 @ 1:23 pm
Anyone try it out yet❓❓
geposted Fri 10 Oct 14 @ 3:40 pm
cannot figure out how to do it....
geposted Sun 12 Oct 14 @ 4:59 pm
Adion's effort doesn't work here (incompatible)
geposted Sun 12 Oct 14 @ 5:25 pm
I really am curious what the big deal is about adding the midi clock to the software? Would adding it really bring this software to it's knees?
geposted Wed 15 Oct 14 @ 7:38 pm
