When unload a deck, the platter in skin does not reset to the initial state, for example:
If a song is unloaded (by the command 'unload') while playing in the mean time, the circular "progress bar" around the platter stills painted.
Need first to stop the song to reset the progress bar, then unload the song.
geposted Tue 30 Sep 14 @ 2:55 am
