Topic: search not loading
Latest problem. Normally when i try to search for a file i can go somewhere like desktop or volumes and it will search everything on it. My search results are still coming up however when I try to load my findings it is coming up with an error. Y?
geposted Tue 30 Sep 14 @ 9:39 pm
Most likely because the file could not be found at the filepath stored in the database.
That happens if you add tracks to your database and sometime later you move the tracks into another folder with the windows explorer (same on MAC).
If you want to move files always do that via the VDJ Browser. That way the database gets updated.
