Forum: Old versions
Topic: Traktor Audio 2 Mk2 with Virtual DJ?
geposted Sat 04 Oct 14 @ 7:44 am
It will indeed work :)
Hi Guys
With the Audio 2 soundcard how do I split channels correctly so main is deck 1 and headphones are in deck 2 ?
Thanks in advance.
Had the same problem as above. Set up as explained by vdj but still sound comes down both channels (main & headphone) from deck 1 and no sound on deck 2. using vdj v8 please can anyone help...
ecco la configurazione per avere sia il master che il preascolto. scaricate pero' i driver traktor dal sito...
I use this sound card.
In Sound Config/Advance, For MASTER: select ASIO and set it to channel 1/2
HEADPHOINES select ASIO and set channel 3/4
Make sure you install the ASIO Driver that came with unit or download the newest one.
