Forum: Old versions
Topic: Right Hand Deck Distortion
Hi Guys have a problem with the Right Hand deck only on version 7.4 in that the sounds distorts really badly left Deck is fine any ideas anyone
geposted Sun 05 Oct 14 @ 4:17 pm
Is the filter dial turned ?
No the filter isn't enabled
I get the same issue randomly. It's like the signal from the cdj gets distorted but only on the right deck. I've found that by going into the options panel & clicking APPLY again it clears it up. However, I have not discovered what the actual root cause is so the problem continues. The set up for me is CDJ 850's & CDJ 400's (happens with both sets of cdjs), dell inspiron windows 7 & VDJ 7.4.2
TSK
