Forum: Old versions
Topic: broadcast issues
I've read through the posts here and it seems there should be "options" when you go to broadcast pc-to-pd direct... I don't have those options and it only offers a ling to an .ogg file... I like the ogg files but nobody else uses them... is there a way to change to an mp3 or anything else usable when broadcasting pc-to-pc direct?
geposted Mon 06 Oct 14 @ 2:42 am
Config->OPTIONS
Search for the BroadcastDirectFormat setting and set it to mp3 (make sure the "Show Advanced Options" is checked)
hi, using vdj 8 to boardcast and after hour hour and half goes all wishy washy sound on broadcast, vdj still sound brill, i shut it down then restart and then ok for hour or two, any ideas .whats wrong' its the sound on the uploud stream
