Forum: Addons
Addons comments
Topic: Pioneer CDJ-400 Advanced Map
ciocePRO InfinityMember since 2004
geposted Mon 06 Oct 14 @ 11:46 am
As follow the modification list respect the original one:
----- v1.0 (5 October 2014) -----
JOG_WHEEL -> effect active ? effect slider 1 or 2 or 3 : Jog
TRACK -+ -> seek -+ 16 & wheel_mode search temporary
SEARCH -+ -> seek -+ 4 & wheel_mode search temporary
REVERSE -> slip mode
LOOPIN -> Pioneer CDJ-2000 loop in style
LOOPOUT -> Pioneer CDJ-2000 loop out style
RELOOP -> holding ? loop? wheel_mode loop_move or jog : loop
TRACK -> effect active ? effect slider 2 : browser_scroll
BACK -> holding ? Big browser view with SWAP 4DECKS skin only : browser_window folders or songs
ENTER -> holding ? sidelist_add : browser_enter
MASTER_TEMPO -> holding ? master_tempo : sync
TIME_MODE -> holding ? smart_cue : display_time remain or elapsed
TEXT_MODE -> holding ? smart_loop : toggle deck number or get_beat_num
MEMORY -> holding ? zoom_scratch -2% : zoom -2%
CALL -> holding ? zoom_scratch +2% : zoom +2%
geposted Tue 07 Oct 14 @ 3:09 pm
thanks for this map
geposted Wed 08 Oct 14 @ 1:40 am
where can i download this map?
geposted Sun 01 Mar 15 @ 1:35 pm
geposted Tue 03 Mar 15 @ 11:23 am
Salve a tutti, volevo sapere se esiste un modo per fare apparire graficamente nella forma d'onda in Virtual dj la selezione del loop in quando premo il tasto loop in nei cdj 400. Perchè di default appare solo quando premo loop out.
Un altra info, se si poteva annullare il tasto loop in una volta premuto, in caso decidessi di non fare piu il loop.
grazie saluti!
geposted Sat 11 Jul 15 @ 1:02 pm
vamos sim fazer a conferecia pra ver se é baum mesmo neh......
geposted Fri 03 Feb 17 @ 6:54 pm
thank you very much top top top
geposted Fri 22 Jun 18 @ 11:02 pm
onde comprar a licença pra esse addon advanced cdj 400 ?
geposted Wed 27 Jun 18 @ 12:23 am
thank you very much this ir mapper dj
geposted Sun 05 Aug 18 @ 4:39 pm
ciao,
non riesco a scaricare il mapper, ho il VDJ7 PRO
come devo fare?
geposted Sat 23 Mar 19 @ 6:14 pm
You need to post in English (or use the correct forum area).
The mapper is for Plus & Pro license holders only - so if you do have a license, it should not be an issue.
Why are you still using VDJ7? If you use VDJ 8 (free upgrade if you do have a license) then you won't need a mapper, as support is built in.
geposted Sat 23 Mar 19 @ 6:19 pm
locodogPRO InfinityModeratorMember since 2013
Pro V7 users will have no problem downloading, at this late date the only replies I can see are going to be home users, purchase 2018 pro.
/thread
geposted Sat 23 Mar 19 @ 7:32 pm
