Forum: Addons
Topic: V8 but by FRUiT - Page: 15
Stupid question but when streaming, is there any visual way to see that the stream is actually streaming while doing your set?
Sometimes shoutcast streams can drop or whatever and I'd like to see an error/visual if this happens.
Is it possible to add that to your skin anywhere? :)
Dunno exactly what kind of visual I could bring to show errors...
Thus you can get some infos on the topbar already :
To be enabled in menu : atomix / topbar / record
Also FYI you can start/stop broadcasting by rightclicking the red 'REC' button.
LSL50 wrote :
lucas569 wrote :
does the skin play nice nice with the new 8.2 version?
Yes it does (so far). been playing around with it for couple of hours, only thing I've noticed is the waveform is a bit juddery but then it settled back down, but so everything works fine
to BDP & LSL50 --- > cool thanks!
Was thinking of flashing red text in place of the above if the connection was lost or similar. :)
As I said I'm an unsure if I can check the broadcasting status... I'll try, but no promises.
I see there was an update to your skin on Thu 09 Jun 16 @ 1:21 pm. Can you please advise what changes were made with this update! Thank you sir!
https://virtualdj.com/forums/194483/addons/V8_but_by_FRUiT.html?page=12
I always put the changelog in the skin's comments.
0.7
- FIX: jukebox custom fileview not showing with day tint
- FIX: cues still showing on songpos when automix engaged in 2/4 decks stances
- FIX: filter knob sometimes not showing in 4 decks stance
- FIX: some font issues addressed
- FIX: Alternate cover view not showing properly
- FIX: vu-meters not showing since build 2126
- mixer: scratch: custom buttons
- mixer: scratch: can toggle filter/gain in EQ layout
- mixer: video: can show 3 more effect dropdowns
- jogwheel: show regular wheel if no cover to display
- jogwheel: can set RPM to 4 beats
- topbar: show limiter instead of nothing if no master
- topbar: record / broadcast widget
- screen: filetype indicator
- screen: artist field menu to select shown infos
- screen: persistent / menu driven scrolling options
- screen: can show next cue info in beats
- screen: can be mirrored
- screen: can show a tooltip with song's infos while hovering
- waveview: persistent, per layout view selection
- waveview: new 'default active decks' view in 2 decks layout
- waveview: new 'All 4' waves at once in all layouts
- waveview: several new scratch views
- waveview: grid on scratch views
- waveview: thin grid shows main beats only
- additional custom buttons on decks
- pitch range percentage text cliquable again
- master / decks switch buttons
- very easy way to set user custom skin tint
- optional workaround for brighter user custom skin tints
- can flatten UI (++quickloop ++dropdowns)
- persistent flat UI
- persistent menu driven clock settings
- slicer / pads
- (alpha) new automix / karaoke layout
- (alpha) new 4 full decks w/ external browser layout
- extended browser / jukebox rework from scratch
- can lock cues by rightclicking their panel's header (with lock indicator)
- can set phrasers to work with 4 or 16 beats
- menu driven beatcounter option
- menu driven cue infos (can toggle times/beats/pos/names/nothing)
- buttons to smoothly fade to left/right with menu driven adjustable length
- hamster crossfader
- menu driven / persistent fx dropdowns text scrolling options
How to set your own custom skin tint
- Unzip the file main.xml from the skin's archive
- Open the file main.xml and follow the instructions in its header
- Done :)
Hey FRUiTilicous,
I like the colored cue points and look forward to when they are also on the buttons ;-)
much love
ray
unfortunately this version of your skin has reset or removed the 3 custom skin colours I had put in place which is no problem, just thought you should know
Oh maybe you reinstalled the skin... It's no news I just answered this guy's request.
If you overrided your saved work with a fresh install, it's obvious the custom tint's disappeared.
Oh I just understood your question... No changes, I believe it it related to the new red "editor's pick" tag added by the team.
BTW thanks for this ! Cheers :)
Whats going on with the track highlighting in the explorer browser?
I am turning the wheel on my MCX8000 and it highlights the first track then when I scroll down the track highlight dissapears and I can no longer tell what track I am on.
Is their a setting for this somewhere or is it an oversight on this update?
DJ James
I found this also. I fixed it by entering the first pulldown 'General Menu' then 'Explorer' and untick 'External'.
Fruit, I have the first pull down 'General Menu' (top left corner of top bar) showing as a flashing yellow triangle (Mac version). Any reason for this?
Mains power not plugged in.
Mains power is plugged in as always.
Just unticked power monitor and it has gone off. Obviously not working properly.
Are you using VDJ 8.2 ?
Thanks, solved my problem just fine.
Anyone else having problems with covers not showing up on the wheels? Mine only show up about half of the time now.
DJ James
Covers showing or not may now depend on if it's hardwritten in the song's tag, or not.
(some can be in 'cache' folder, and some others could be just pics laying along the file with the same name)
The skin is now querying the 'has_cover' function, in order to show the full wheel with cues / loops / beats visuals if no cover is found (instead of a rotating ugly title / artist).
Any users of Fruit figure out how to stop the Tab button from cycling through all 4 decks even when in 2 deck display mode.
Is there a setting, a newer version or is this the way it is?
I just want to be sure. While experimenting I've accidentally loaded tracks onto Deck 3/4 even in 2 deck display mode. I thought that this was a global fix for all skins a while back.
39%
