Forum: Addons
Topic: V8 but by FRUiT - Page: 28
FruitPRO InfinityMember since 2003
Well if you want it with caps you'll need to edit the xml file.
Line 2368~2379
You'll find there a bunch of <text format="2 decks"/> at the end of each line. That's what you want to change.
Cheers !
geposted Thu 09 Feb 17 @ 6:39 pm
Line 2368~2379
Cheers !
Done Thanks for your Quick Response.!!!
geposted Thu 09 Feb 17 @ 10:02 pm
Np ^^
geposted Fri 10 Feb 17 @ 12:25 am
Fruit wrote :
Np ^^
One more question...FRUiT included are 2 pictures for you to see how come if on this section you choose 4 effects all the same or 4 different all is ok while you're using them but after you're done and close virtualDJ and reopen VirtualDJ the setting it's all gone and you have to start selecting the effect all over again in order to use them again it happen even if you click on general menu and save the settings, how can I set it to stay and don't have to set them every time I close and Reopen VirtualDJ is there a way to make them stay save once and for all, your help is Appreciated Thanks and Best Regard??? PS also when are we gonna have those Jag/wheel spinning, any time soon???
geposted Sat 11 Feb 17 @ 4:10 pm
Again that's up to Atomix team I'm sorry... The software saves only one master fx, thus it can use several at once.
The jogwheel will be in next release. I didn't start it yet and it might take long time to come. So I'm sorry but don't expect it too soon. It's in the todo list ^^
Cheers !
geposted Sat 11 Feb 17 @ 4:42 pm
@FDilonez
That's up to atomix. Not FRUiT... Those effects can't be saved. Maybe start a post on the wish list section.
Cheers !
Thanks.!!!
geposted Sat 11 Feb 17 @ 4:59 pm
PressNPlayDJ wrote :
@FDilonez
Thanks.!!!
Best DJ software thanks!
it may ugly to open brower zoom via laptop?
geposted Wed 15 Feb 17 @ 3:19 am
i, I didn't understand that question...
geposted Thu 16 Feb 17 @ 4:08 pm
I think perhaps he wants to turn on/off browser zoom from a keyboard key.
geposted Thu 16 Feb 17 @ 5:33 pm
Playlist open and close via laptop
geposted Thu 16 Feb 17 @ 7:54 pm
geposted Thu 16 Feb 17 @ 7:55 pm
Then the shortcut should be browser_zoom.
geposted Thu 16 Feb 17 @ 10:06 pm
it's alright software works well, thanks
geposted Sat 18 Feb 17 @ 1:36 pm
testing your BRILLIANT SKIN
geposted Tue 14 Mar 17 @ 2:17 am
Thank you :) Any thoughts ?
geposted Wed 15 Mar 17 @ 12:47 pm
So far it's by far the best I've ever seen!!!!
geposted Thu 16 Mar 17 @ 12:02 am
lincol2PRO InfinityMember since 2011
Agree.
geposted Thu 16 Mar 17 @ 12:03 am
yes fruit....best so far...and continuously improving
geposted Thu 16 Mar 17 @ 12:41 pm
74%
