bogart wrote :
Here is another situation.
When type in song or artist in search it also switches to browser mode
Hi Bogart,
I had this happen to me when I updated the skin but would return to standard view after a couple of seconds of inactivity, I found the option in the top left corner.
Under Explorer make sure "device managed" & "allow browser zoom" are unchecked.
geposted Sun 30 Jul 17 @ 9:36 pm
Seems to be the problem. Don't know how that happened.
THanks
THanks
geposted Tue 01 Aug 17 @ 12:12 pm
It was an experimental feature.
Due to some recent changes, I'll have to remove it.
geposted Tue 01 Aug 17 @ 12:16 pm
FRUiT thank you for creating this great skin! One item that I'm having trouble with is trying to switch between the "splitted" and "(type 2) Horz 2 waves" rhythm zones with a button?
geposted Fri 04 Aug 17 @ 1:56 pm
Thanks FRUiT for awesome skin. My virtuadj ver. 3780 restart the pc when use your skin. My system is windows 10 and work fine with the skin default, but i loved your skin. Which version is compatible with your last version skin? Thanks!
geposted Sun 06 Aug 17 @ 9:56 pm
The latest release version is 3798. The latest eary access version is 3846.
Try one of those. Your version is old.
geposted Mon 07 Aug 17 @ 5:06 pm
Disregard, I just had to read the main.xml file a little closer. It's.......
'var '@$v8bf_wave_4d' 5 ? set '@$v8bf_wave_4d' 60 : set '@$v8bf_wave_4d' 5'
geposted Fri 11 Aug 17 @ 9:58 pm
awesome update
geposted Sat 12 Aug 17 @ 9:07 am
Thx gees :)
Those vars've been a real pain to manage. Your button might lead to some unwanted behaviors. Hope not ^^
geposted Tue 22 Aug 17 @ 11:01 am
FRUiT can you please add an option to brighten or make thicker, the wave form grid? thx
geposted Fri 25 Aug 17 @ 3:43 pm
Hola Fruit, déjame felicitarte por tu skin, es fascinante!
Me gustaría que cuando conecte mi controlador y utilise la perilla para seleccionar alguna canción, el browser no se amplié y deje la vista tal y como esta, esto también sucede cuando hago clic en el botón de "Sampler" o en el "Side List". te agradezco mucho por tu ayuda.
Gracias.
Gracias.
geposted Sun 27 Aug 17 @ 12:09 am
@Onsteeng
In future please post in English, or use the Spanish forum area. Thanks.
geposted Sun 27 Aug 17 @ 7:18 am
Been using 0.8.2 FRUiT along with VDJ 8.2 b3846 and just noticed the "gain" led's no longer seem to flash when I up the gain volume. Am I missing a setting? Thanks :)
geposted Wed 30 Aug 17 @ 6:37 pm
True, no you aren't...
I'll try to sort this out, if not a vdj bug...
Seems one of the master's limiters isn't working anymore as well...
geposted Fri 01 Sep 17 @ 11:49 am
In the Extended Browser view, the text on the left deck is scrolling over the centre area.
geposted Sat 02 Sep 17 @ 7:10 am
Cheers FRUiT hope it's something that can be easily fixed by you. :)
geposted Sat 02 Sep 17 @ 7:47 am
hey fruit...was just wondering..does your skin have an option to border each individual deck layout and select/highlight according to pfl..not the waveform..the deck itself. and if is not implemented already..can i add it to the update wishlist??? thanks in advance
geposted Sun 03 Sep 17 @ 3:17 pm
Hello Fruity, I have a problem: in the skin 2 decks are selected, but when I press TAB it switches to two other decks without their being activated. How do I solve this problem? Thank you.
geposted Mon 02 Oct 17 @ 5:01 pm
Hi LR
try this, go into settings / controllers / keyboard and paste this into the action for Tab(I think it's right down at the bottom of the list), this will create a custom mapping and should solve the problem.
deck left select ? deck right select : deck left select
Best
ray
Best
ray
geposted Tue 03 Oct 17 @ 1:18 pm
Ty Ray :)
geposted Tue 10 Oct 17 @ 11:53 pm
