Fruit wrote :
Do a rightclick on the 'video' tab in the mixer section.
Thank you fruit, works a treat.
geposted Sun 28 Jan 18 @ 12:14 am
Np :)
geposted Mon 29 Jan 18 @ 3:00 pm
Hello! Love the skin. Started using it and haven't looked back.
Couple things.
Is there a way I can shorten the 'deck unload' time? Currently, it's about 2 seconds. The default skin is about 1 second. 2 seconds slows me down, believe it or not! Or, is it possible to set an option to choose deck unload time?
Also, is there any way you can get the beat grid to reverse direction so it flows left to right? I'm sure it's been asked a hundred times but I just recently switched from VDJ 7 to 8 and after using the left to right option for years, I'm really used to it.
Thank you. I really appreciate the excellent work you've done on this skin!
Couple things.
geposted Thu 08 Feb 18 @ 2:47 pm
OK< I got the deck unload time issue taken care of. Still would love to see that reverse direction beat grid, though! Thank you!
geposted Thu 08 Feb 18 @ 3:32 pm
Can you please share what you did to shorten the deck unload time as I would like to shorten mine also.
geposted Thu 08 Feb 18 @ 4:36 pm
This is what I did. My first time editing a skin file so at your own risk.
Find the VDJ folder then find the Skins folder.
Make a copy of the V8 but by FRUiT zip file and name it V8 but by FRUiT 2.
Unzip the copy.
Open the main.xml file in Notepad.
Search for 'unload' then look for 1500ms.
For every instance of 1500ms you find, change it to the value you want. I changed mine to 500ms (1/2 second).
There are 4 instances you'll have to change.
Save the file.
Rezip the contents.
Open VDJ and select the V8 but by FRUiT 2 skin.
Your unload time will be 1/2 second now.
Unzip the copy.
Save the file.
Rezip the contents.
geposted Thu 08 Feb 18 @ 5:28 pm
Thank you! I will give it a shot!
geposted Thu 08 Feb 18 @ 6:12 pm
Glad you sorted this.
Historically, the unload time WAS shorter previously, then I have been forced to increase it a bit cause some people were unloading by mistake.
We've got a thread for asking about waveform direction, here you go :
https://fr.virtualdj.com/forums/187263/Wishes_and_new_features/Wave_Form_Display_Direction.html?search=richmond&page=8.05
geposted Fri 09 Feb 18 @ 4:11 pm
[delete]
geposted Fri 09 Feb 18 @ 4:12 pm
Need some assistance please.
The album art was always loading onto the jog wheel.
Now it does not; even though the artwork is still showning
up in the tag.
I went to download the skin again. It shows version 8.2 in the
download section; however when I download it and check
the version, it shows version 8.0.
Can you advise please?
Thanks
up in the tag.
Thanks
geposted Sat 24 Feb 18 @ 6:00 pm
Update
After downloading the skin again, cover art is back to working.
Still do not understand the version showing 8.2 but after downloading it shows 8.0
geposted Sat 24 Feb 18 @ 6:28 pm
Hello !
I've got a blink line on the top of my screen with this skin...
Anyone to help me ??
Thanks ;)
Thanks ;)
geposted Fri 16 Mar 18 @ 8:22 pm
invulnincible wrote :
Hello !
Thanks ;)
Thanks ;)
I would think a screenshot pointing where would help the skin creator identify and make possible correction.
geposted Sat 17 Mar 18 @ 3:07 am
When I put it in 2 decks mode anyway it still goes to deck 3 and 4.
You just need to remove decks 3 and 4 so that the TAB key works correctly for decks 1 and 2 only.
geposted Mon 19 Mar 18 @ 5:40 am
Hi JuninkD,
go into the options in VDJ, choose controllers and then keyboard.
scroll all the way down to find TAB and then paste this command in
deck left select ? deck right select : deck left select
That should resolve the problem that you are having
Best
Ray
Best
Ray
geposted Mon 19 Mar 18 @ 10:02 am
Hello !
Thanks ;)
Thanks ;)
Hi,
Difficult to explain but :
In full screen : it's like a scrolling bar (in blue on the top of the screen which go from left to right - like a track loading on a deck) or
Not in full screen : i have pixels and blues lines
When the song is loaded you have a ''cursor'' (black part on the blue line from left to right while the track is playing)
Do you see the problem on pictures ???
THX
geposted Thu 22 Mar 18 @ 9:51 am
Hey fruit...one question and one request.
How the markers in your skin work in the waveforms(scratch and the top panel) in relation to the cue points..is the cue on the marker...before or after?
Secondly..please include pitch quality value 3(new) in the little box in the skin where u change pitch quality.
Thanks..keep up the good work.
geposted Fri 23 Mar 18 @ 11:49 am
I believe you are running a mac. This bar was supposed to be invisible. I used an exploit working on windows, but not ios.
The skin is still working, and the issue should be addressed in in next release.
geposted Mon 26 Mar 18 @ 8:50 am
Not sure I understand this, the cue LINE indicates its pos.
geposted Mon 26 Mar 18 @ 8:54 am
Yep, I’m on Mac
Great job so far, it s just a small thing with no issue on the program...
Thanks for all !
geposted Mon 26 Mar 18 @ 11:21 am
