Forum: Beta Builds Regression Bugs
Topic: BUILD 1995 - Page: 1
- improved timecode engine
- new timecode config interface, with automatic calibration
- new algorithm for timecode pitch slider (with or without option timecodePitchSliderIgnoreBend)
- changed timecode smart mode needle-drop behavior
-vibration threshold for hid jogspeed
- fixed some potential random crashes
- better search in database when using accents and/or greek/russian/hebrew alphabet
-allow sampler_pad 1 "4x2x2" for skins that need a specific pad layout
-fix possible crash when analysing corrupt files
-Fix mp3 seek bug
-Fix not being able to set cue points before the start of the song
-Fix video mixing with autoMixDualDeck
-Fix videoAudioOnlyVisualisation sometimes activated for a very short time when loading a new video
-fix high cpu usage when using 2 pioneer controllers with same mapping
-Fix reverse on motorwheel controllers not being instant
-Fix drag files from Finder on mac with retina screen
-Fix loop_select having same range as loop_half and loop_double and not rolling over for endless encoders
-Fix iTunes database problem with recent iTunes update
-Fix 'other' plugins not correctly loaded when put in AutoStart
geposted Wed 08 Oct 14 @ 9:08 am
Hi,
Don't even open for me! I have this error message (in french on xp):
"Le point d'entrée de procédure InterlockedCompareExchange64 est introuvable dans la bibliothèque de liaisons dynamique KERNEL32.dll"
geposted Wed 08 Oct 14 @ 9:57 am
I hope you (Atomix) have not dropped XP support...
geposted Wed 08 Oct 14 @ 10:08 am
No, a fix is being put in place :)
geposted Wed 08 Oct 14 @ 10:09 am
Yes, regression bug on XP.
If you got XP and had 1995 download (and now you're stuck), manually download 1996:
http://virtualdj.com/download/virtualdj8/pc/1996/zip
(If you didn't update yet, don't worry, you'll update directly to 1996 and everything will be ok.
And, if you don't run Windows XP, then no worries neither)
geposted Wed 08 Oct 14 @ 10:17 am
I just ran VDJ 8 and it's still only offering me 1995.
geposted Wed 08 Oct 14 @ 10:42 am
improving the awesome truth, though videoaudioonlyvisualisation to produce freezing enabled and disabled ...
geposted Wed 08 Oct 14 @ 10:56 am
I couldn't try version 1995. I'm on 1996.815 now. :-)
geposted Wed 08 Oct 14 @ 11:44 am
espepePRO InfinityMember since 2009
Works perfect !!!! Im wonder what is the diference 1995-1996 ,im playing in 1995 works perfect!!!!!!
geposted Wed 08 Oct 14 @ 12:42 pm
1996 is an update that resolved the issue for some users with build 1995 on XP machines.. all good here on W7 ;-)
geposted Wed 08 Oct 14 @ 12:45 pm
1996 works now on xp.
Quick fix!
geposted Wed 08 Oct 14 @ 12:56 pm
NVM problem went away after a restart
geposted Wed 08 Oct 14 @ 2:04 pm
What is this "vibration threshold for hid jogspeed". I am just above a double 18, and it vibrates my jog wheels on my RMX2, which moves the track in the cue mode. Will this help me, or is there something else I can do to cut down on the sensitivity of the jogs?
geposted Wed 08 Oct 14 @ 2:19 pm
It only applies to speedwheel controllers - ie CDJs I'm afraid Rick.
geposted Wed 08 Oct 14 @ 2:21 pm
Thanks my brother. I'll try jogsensitivitycue to see if that helps.
geposted Wed 08 Oct 14 @ 2:27 pm
DJAVIPPRO (OEM)Member since 2016
"It only applies to speedwheel controllers" like what for example ? pioneer 350, 400 , 850... ?
geposted Wed 08 Oct 14 @ 3:26 pm
Current controllers with a speedwheel are the following:
Pioneer CDJ 350, 400, 850, 900, 900 Nexus, 2000 and 2000 Nexus
Pioneer XDJ-AERO
I believe the definitions will have to be updated to support this new function so you may not see any difference until it has been done.
geposted Wed 08 Oct 14 @ 3:39 pm
Im using CDJ 800's with timcode... what does that mean for me?
Pioneer XDJ-AERO
It will be updated automatically Or by another update ?
geposted Wed 08 Oct 14 @ 3:51 pm
Internal def files are updated silently.
geposted Wed 08 Oct 14 @ 4:18 pm
51%
