I just saw a link to download the text to the songs. I tried it with ten songs and it was way off. Is there a way to link it and or is it because I use a poi to start the songs? Neat idea if it works.
    geposted Wed 15 Oct 14 @ 8:54 pm
          Link to the plugin please??
    geposted Thu 16 Oct 14 @ 7:50 am
          Not a plugin, it's built into the software .......
http://www.youtube.com/watch?v=Z2UZ2dpOuI0&feature=youtu.be
geposted Thu 16 Oct 14 @ 12:49 pm
          The lyrics are just .lrc  files that you can open with any text editor.
They are stored on the same location with the song, and they have the same filename.
You can change the times inside the .lrc file, but you'll have to do it manually.
geposted Thu 16 Oct 14 @ 2:19 pm
          This is a really cool feature, thumbs up to team. Could you add a support for enhanced lrc files? Here's an example of it:
[00:08.18]FEEL<00:08.35>ING <00:08.46>MY <00:08.59>WAY <00:09.12>THROUGH <00:09.40>THE <00:09.57>DARK<00:10.09>NESS<00:10.54>
[00:12.05]GUI<00:12.33>DED <00:12.58>BY <00:12.82>A <00:13.01>BEAT<00:13.30>ING <00:13.48>HEART<00:13.93>
[00:15.90]I <00:16.13>CAN'T <00:16.33>TELL <00:16.79>WHERE <00:17.13>THE <00:17.34>JOUR<00:17.82>NEY <00:18.10>WILL <00:18.34>END<00:18.79>
This is the regular lrc, already supported by VDJ:
[00:08.18]FEELING MY WAY THROUGH THE DARKNESS
[00:12.05]GUIDED BY A BEATING HEART
[00:15.90]I CAN'T TELL WHERE THE JOURNEY WILL END
geposted Thu 16 Oct 14 @ 3:25 pm
          Maybe you could add some options for fonts or a background transparency, just like the way TellyMedia does:
http://i62.tinypic.com/20u4eme.jpg
geposted Fri 17 Oct 14 @ 3:04 am
          How do you edit it or sync it.. Half the songs have Chinese In them.. The timing sucked as it was late or slow. Cool idea when it worked!
    geposted Sat 18 Oct 14 @ 1:02 am
          Can you stack this on top of video or telemedia or video effects?
    geposted Sat 18 Oct 14 @ 1:05 am
          To edit lrc file, just open it with Notepad and delete the strange stuff.
If you want to find the right lrc for your song, try http://www.lyricsplugin.com/ with some other player.
If you want to put some visualizations in the background, try with Tellymedia (Layouts > Alpha Transparency).
geposted Sat 18 Oct 14 @ 2:53 am
          How do you adjust the speed so the text actually matches the song?
    geposted Sat 18 Oct 14 @ 8:42 pm
          You must play mp3 with it's original BPM, so forget about BPM syncin', it won't match in that case. If you don't know how to adjust lyrics timing, you can always edit music file, by cutting or adding a seconds in the beggining.
    geposted Sun 19 Oct 14 @ 4:54 am
