Topic: Problem: moving virtual folders
I have 3 club folders and within them a number of subfolders for each girl's playlist. When I try to move the subfolders to put them in alphabetical order, they often end up as a subfolder of playlists...
- there should be an option to sort by date created, kind, alphabetical ascending, alphabetical descending, size etc
- there should be an option to lock content so other non authorized DJs don't mess up the playlists
geposted Thu 16 Oct 14 @ 6:46 pm
find the "folder" files in windows it is created automatically after you move something... Documents\VirtualDJ\Folders here is the most important one, but it creates these files all over your harddrive... search it!
if you have a good folder layout close VDJ8
then make the "folder" file read only now everytime you open vdj 8, layout is same again
hope it helps cheers
geposted Thu 13 Nov 14 @ 10:29 am
