Hi,
I am using a Pioneer MEP-7000 (Controller) and Pioneer DJM 5000 mixer.
Using VDJ 8, the sound quality is awful! I have my Zero DJ set to 0.750000, Auto gain set to Yes, Exclusive Audio Acces: No.
Any ideas on how I can make it sound better? Sounds really distorted.
Thanks!
Thanks!
geposted Fri 17 Oct 14 @ 5:54 pm
Which sound card (driver) is the one that you use in the Audio Setup and what is the selected latency for this ?
geposted Fri 17 Oct 14 @ 8:04 pm
Hi - I am using the Pioneer - Latency is Automatic (256) and also sample rate is Automatic (41000).
Thanks!
Thanks!
geposted Sat 18 Oct 14 @ 11:24 am
