Forum: Old versions
Topic: i need to fix history playlists
Hi whenever i go to my history playlists it will not load the tracks and gives error message in the play window.
After further investigation i found that the history playlist has lost all the path info and tells me that the tracks have never been played.
Playlist fixer will restore the lists, but when i go to download the program it tells me that my licence is not valid but it shows as valid in my account.
I hope someone can help because the only way left is to search each track using the search bar and there is a lot of history listings.
geposted Tue 21 Oct 14 @ 5:31 am
Can you see if its only the Drive Letter that has been changed.. Or is it more ? You could manually batch replace the part that has been changed.
I have the same issue... I changed from mac to windows and my history is showing but when I try to load a song it errors? Any idea?
I believe the slash is the other way around (Mac vs Windows)....
