Topic: mp3 Error
Hi
I am busy scanning my music, and I have had a few that will not play in Infinity 8 it shows error when loading into either deck. So i removed the file from the folder and I wondered why it would not play. So I tried the same file in Virtual DJ 7 and it was okay. I even removed the jpg art and it still would not play in Infinity. So i converted the file to flac as most of my music has been ripped to that codec, and the file played in infinity.
I have experienced this problem before in earlier builds of Infinity, but thought that the problem had been fixed. I did do a search but could not find the thread. Can anyone else confirm this type of behaviour and if there is a fix.
geposted Wed 22 Oct 14 @ 5:41 am
You converted the files the FLAC.......so you've not got any more "faulty" ones that you can pass to the devs?
Ideally they'd need the file itself, but it'd even be useful to know what format it was / bit rate / sample rate / VBR vs CBR etc.
Hi i have the original MP3 file still they were ripped at 320kbps at CBR
File has been sent to the Dev team. Thanks for the help
