Hi
Does anyone have any profiles for the 30 band graphic made by SBDJ i already have the profiles for the 10 band graphic but would like to try the 30 band graphic
geposted Wed 22 Oct 14 @ 7:36 am
im working on it!!!! I let you kwon when is ready.cheers
geposted Sat 25 Oct 14 @ 10:23 am
Many thanks pezamigo 2
geposted Sun 26 Oct 14 @ 6:48 am
Ready!!! I send the files for eq30 to review.For now use eq10 profiles.cheers.
Profiles for EQ10 Approved http://www.virtualdj.com/plugins/index.html?addonid=16774 18 profiles
Profiles for EQ30 Pending review http://www.virtualdj.com/plugins/index.html?addonid=80145 3 profiles
geposted Sat 01 Nov 14 @ 7:50 am
many thanks pezamigo 2 looking forward to getting these profiles.. )
geposted Sun 02 Nov 14 @ 7:56 am
Nice work, thanks for that.
Best Regards
ray
Best Regards
ray
geposted Sun 02 Nov 14 @ 8:06 am
Why do these profiles take a long time to get approved, its not the plugin just some profiles created within the plugin. Please can you look into this...
geposted Mon 03 Nov 14 @ 8:51 am
It would seem that the Devs have missed this one. Or there seems to be a problem
geposted Wed 05 Nov 14 @ 3:39 am
Idk why they take to long !!!idc i send the files ready .is all i know...
geposted Wed 12 Nov 14 @ 9:53 pm
I had a quick look at this and unless I'm missing something there are only 2 profiles and both are almost flat anyway?
geposted Thu 13 Nov 14 @ 8:34 am
Why would you need preset profiles anyway?
Surely the point of this plugin is to get the sound the way you want moving the sliders then save it as a preset?
geposted Thu 13 Nov 14 @ 2:51 pm
Simple because are free and save time. many plugins like eq30 coming whit presets and I not have time to create more right now. maybe next year.
geposted Fri 14 Nov 14 @ 11:06 pm
.....but they are profiles for someone elses sound system.
The chances of you having exactly the same equipment and playing in exactly the same room with the same number of people are remote. :-)
Each person should be setting their EQ to sound good for their own equipment and environment.
geposted Sun 16 Nov 14 @ 10:45 am
This is the exact reason I don't include any. Presets like 'Rock' and 'Pop' are meaningless.
geposted Sun 16 Nov 14 @ 8:51 pm
Hey Scott,
Been using this plugin on master output since moving to the SX2 which doesn't have EQ on the booth out like the MC6000.
Works a treat, thanks for taking the time to develop this one.
Keith
Keith
geposted Mon 17 Nov 14 @ 6:47 am
No problem :)
geposted Mon 17 Nov 14 @ 8:53 am
