Forum: Old versions
Topic: Traktor Kontrol F1
The Z1 and the X1 mk2 have been added. Any hope for the F1 next? With sample pad control?
geposted Thu 23 Oct 14 @ 12:24 pm
Currently we try to support all Native Instrument devices we can lay our hands on. Since Native Instruments does not provide us sample units, we have to rely on units we can find on a volunteer basis.
If a Kontrol F1 device comes in our hands, then yes we will support it.
im going to be looking for one cheap once im done with the S2 MKII, should have one by the end of next month
OK. Great. Waiting on some good X1 mk 2 mappers as well...
I have seen other threads mentioning Teamviewer sessions to help with mappings. I have both PC and Mac with an F1, Z1, X1, and X1 mk2. I am more than willing to help out.
Let me know if I can be of any assistance.
unfortunately i do all my HID work on my own hardware so that i can test it as i go and see the output.
Kontrol F1 will be supported in the near future.
Thank you for your patience!
No worries. Just trying to help.
For the X1 mk2, is there a mapper where the LEDs display the number values of the loops? Or any plans to implement this?
Love all the great stuff that this community produces! Wish I had more to contribute from a programming standpoint...
On the default native mapper of X1 MK2 you should see the length of the loop on the LCD.
Remember that you have to use it in HID mode
Sorry. Just seeing this...
HID mode? How do I enable that?
Just plugged it in with no other controllers connected. Numbers showed up. I usually use it with a MC6000 and Dicers. When I use it with that setup, the LCDs display a weird looking pattern.
Any possible issue there?
Can you please post a picture of it ?
I will when I have it all setup. Possibly tomorrow.
Seems to be fixed with the new update. Kudos.
