Topic: Pitch wont lock!
love the way 8 is going just cant get the pitch to lock and not move... I need it locked for spanish music .
I have been all over options... any Ideas to stop it from moving ? Thanks
geposted Sun 26 Oct 14 @ 6:00 pm
Somthing like 7 a Key Lock to the lock the pitch would be good. :-)
Hi,
did you set the following options to "no" ?
"autoBPMMatch" in audio and "MasterTempo" in options
You can set in the Audio-Options "resetPitchonLoad" to "No" and "PitchLock" to "Yes", too.
Oh, I forgot, that you have to enable the advanced options.
Hi guys, I haven't yet tried this solution, but I think you're asking the same thing I've been dying for: is it possible in 8 to lock a custom pitch, then change to a different tempo? I used to do this with older VDJ versions easily with keylock, but 8 always jumps back to native pitch when you enable "master tempo" to change tempo. My apologies if it's a repeat, but I want to clarify if this is what you're addressing here or not.
Thanks Djragman but i Tried all the settings and it still moves..i will keep trying to figure it out
FINALLY FIGURED IT OUT! blank out your pitch range ALSO! worked for me..
