It would be a great opportunity if one day VDJ supports the spinning platter of the excellent Denon DN-HS5500.
Ce serait géant de voir un jour VDJ supporter le plateau tournant de l'excellente Denon DH-HS5500 !!!
Thanks Merci
geposted Tue 04 Nov 14 @ 9:50 am
What makes you think VDJ doesn't support the HS5500?
It works better in VDJ 8 than it has done for quite a while (since VDJ 6).
It's not perfect, but then the same is true of other motorized platters.
geposted Tue 04 Nov 14 @ 10:53 am
What he means is the spinning platter is unusable since every manipulations (start, scratch etc.) cause the song to speedup for like 4-5 seconds (both pitch and tempo). Currently you can use it only for scratching with samples loaded on the other deck. Forget about beat juggling or basically any scratching with a song.
geposted Wed 12 Nov 14 @ 11:34 am
