Topic: sampler effects record
I have purchased vdj8 and downloaded and installed the software,i have used vdj7 before and could use the browser sample effect and record tabs on that but on vdj8 it just stays on browser the rest dont do anything?? Any help would be great...thanks
geposted Wed 05 Nov 14 @ 4:36 pm
Those tabs were used by VDJ 7 and earlier, and they're no longer required.
You should use a skin that is designed for version 8.
