Discussion about Hercules RMX 2 Optimized Mapper
geposted Fri 14 Nov 14 @ 12:48 am
As follow the modification list respect the original mapper:
----- v1.0 (13 Nov 2014) -----
SHIFT -> wheel_mode "search" while_pressed
SCRATCH (vinyl) -> var '$shift' ? prelisten : holding ? toggle '$browsersize' (work with dedicated RMX 2 Skin for VDJ8)
LEFT -> var '$shift' ? browser_window -1 : browser_folder
RIGHT -> var '$shift' ? browser_window +1 : browser_window 'songs'
EQ_KILL_HIGH -> var 'shift' ? eq_kill_high while_pressed (temporary Kill)
EQ_KILL_MID -> var 'shift' ? eq_kill_mid while_pressed (temporary Kill)
EQ_KILL_LOW -> var 'shift' ? eq_kill_low while_pressed (temporary Kill)
PFL -> wheel_mode "browser" while_pressed
LOAD -> var '$shift' ? sideview 'sidelist' ? sidelist_add : sideview 'automix' ? playlist_add
Original Mapper & Setup info: https://virtualdj.com/documents/Hercules%20RMX2%20-%20VirtualDJ%208%20Operation%20Guide.pdf
Dedicated RMX 2 Skin for VDJ 8: https://virtualdj.com/plugins/?search=Hercules+RMX2
geposted Fri 14 Nov 14 @ 3:31 am
