Topic: Track Cleaner Improvements
Hi guys I am sure anyone using the track cleaner will agree - it needs some big improvements.
1. ZOOM! Why can't I zoom into see what I am working with? Zoom works with POI editor perfectly. Why can't it be implemented to track cleaner?
2. Allow cue points to be used as anchors in the editing process.
3. Allow the end of the "remove" area to be snapped to cursor so that we can be more precise with the editing.
4. When a song is edited (I am using mp4 music videos), if you use the track cleaner on the edited version the graphics do not line up with what is playing. This is a BUG I believe.
Thanks
geposted Fri 14 Nov 14 @ 1:57 am
I don't use the track editors so I can't comment but #2 seems reasonable
Also (all editors are guilty of this)
http://pbrd.co/1qHsRnQ
