Forum: VirtualDJ Skins
Topic: can we have 90 degree text
or sideways text in skin?
geposted Sat 15 Nov 14 @ 7:07 pm
FruitPRO InfinityMember since 2003
Of course :
direction="up"
geposted Sun 16 Nov 14 @ 11:07 am
That's not in the SDK :-)
geposted Sun 16 Nov 14 @ 11:30 am
had a further mess around and came up with orientation="vertical"
geposted Sun 16 Nov 14 @ 12:14 pm
Oops, my bad sir !
geposted Sun 16 Nov 14 @ 4:21 pm
...but in some skins :)
Yes you can. I will get this added to the SDK.
I gather you've worked this out Mark, perhaps post the code for others ;-)
geposted Mon 17 Nov 14 @ 4:19 pm
<textzone orientation="vertical">
<pos x="0" y="0" />
<size width="20" height="970"/>
<text size="15" format="`get_browsed_filepath`"/>
</textzone>
geposted Tue 18 Nov 14 @ 2:02 pm
<pos x="0" y="0" />
<text size="20" action="get_browsed_filepath"/>
</textzone>
You can also use action - rather than having the ` `
geposted Tue 18 Nov 14 @ 2:32 pm
I've just tried using this to display a limit warning down the centre of a VU meter (between the L & R bars) and found that the entire text is sideways.
What I wanted was the letters to be the correct way up, but one under the other, like:
T
H
I
S
I can use a visual instead, and put bitmap letters into the PNG file - or have a separate textzone for each letter, one below the next I suppose......
geposted Tue 10 Feb 15 @ 12:17 pm
Use /n for new line so your text would like like this:
"T/nH/nI/nS"
geposted Tue 10 Feb 15 @ 12:27 pm
Thanks, I'll give it a try.
[later] No, that doesn't work. It shows everything literally, including all the /n.
It works OK with separate textzones for each letter, below each other. :-)
geposted Tue 10 Feb 15 @ 12:31 pm
[later] OOPS!!!!
It should be \n
"T\nH\I\nS"
Sorry for the confusion :)
geposted Tue 10 Feb 15 @ 2:15 pm
and make sure the height of the textzone is big enough to fit all the lines
geposted Wed 11 Feb 15 @ 12:50 am
