Topic: vdj8 crash
i was testing vdj8 at my pub and kept vdj7 open in case vdj8 crashed it crashed after 3 hours at the moment i was using the auto mix editor and using the auto mix mode on,
also i enabled in auto mix options(remove played songs automatically) the problem is also i can't see the playing track in the auto mix editor also i can't move the tracks upside if i wanna change the order while am playing in auto mix mode!!!! btw i use macbook pro i7 16gig ram ssd ,the problems are happening in vdj8 mac ver.dint test it on pc version
geposted Sun 16 Nov 14 @ 4:06 pm
