Topic: BPM & Key Too Close Together!
Is there anyway you can give song BPM & Key a little more space apart in the browser? They are really scrunched together!
Thanks!
geposted Wed 19 Nov 14 @ 11:17 pm
I am not as familiar with VDJ8, but with VDJ7, you can grab the header separators and slide them left and right. I assume you can do the same in VDJ8, at least I hope so!
Yes you can.
You can move the separators like in VDJ 7 but BPM & Key still stay on top of each other.
Reorder them.
Yes, you could re-order them but why do you have to? You can make as big of a separation as you want.
But the incrimined field is "key", not "harmonic"...
The "key" field is left aligned.
