Topic: VDJ SKINS WORKING WITH VDJ 8!
I am running a VDJ 7 4 deck skin made by DJdad with VDJ 8 and it is working perfect! Headphones, Mic, Drop Box, Samples, waveform, sound engine Etc, Etc.
I only wish that colored folders would show up as colored folders in VDJ 8, they remain white pointless of the skin used. So far I am very impressed with VDJ 8!
I simply added the VDJ 7 skins to the VDJ 8 "Skins" Folder and changed the skin in the config menu like normal.
geposted Thu 20 Nov 14 @ 4:41 pm
there's a setting to use shell icons enable it.
what is the bug?
