is there anyway to map the buttons on the slip_roll effect? by deun-deun. i hate to have to click the buttons. would love to be able to map it to ns7
geposted Sat 22 Nov 14 @ 9:36 am
Sure it's possible, the buttons of the FX work while pressed, which make it function similar to how loops work with loop_roll on (except the fx will work within a loop)
I can help but I need more info,
The way I use the loop roll FX is if the FX is active (by pressing button 1 b1) if I press another button (b2) then it loops the same point in the track but the length changes, but if I press b1 and the loop length is as it should be for b1 it turns the FX off
We'll have to do some keyboard mapping to test that what I'm thinking is your desired behaviour, I have 4 (keyboard) buttons
Button 1
effect_active 'loop roll' ? effect_slider 'loop roll' 1 0.375 ? effect_active 'loop roll' : effect_slider 'loop roll' 1 0.375 : effect_slider 'loop roll' 1 0.375 ? effect_active 'loop roll' : effect_slider 'loop roll' 1 0.375 & effect_active 'loop roll'
button 2
effect_active 'loop roll' ? effect_slider 'loop roll' 1 0.5 ? effect_active 'loop roll' : effect_slider 'loop roll' 1 0.5 : effect_slider 'loop roll' 1 0.5 ? effect_active 'loop roll' : effect_slider 'loop roll' 1 0.5 & effect_active 'loop roll'
Button 3
effect_active 'loop roll' ? effect_slider 'loop roll' 1 0.625 ? effect_active 'loop roll' : effect_slider 'loop roll' 1 0.625 : effect_slider 'loop roll' 1 0.625 ? effect_active 'loop roll' : effect_slider 'loop roll' 1 0.625 & effect_active 'loop roll'
Button 4
effect_active 'loop roll' ? effect_slider 'loop roll' 1 0.75 ? effect_active 'loop roll' : effect_slider 'loop roll' 1 0.75 : effect_slider 'loop roll' 1 0.75 ? effect_active 'loop roll' : effect_slider 'loop roll' 1 0.75 & effect_active 'loop roll'
So these keys will loop roll FX 1/4 beat, 1/2beat 3/4 beat, 1beat (in order) try them as a keyboard mapping, if the behaviour is right for you we can then expand to include all the lengths you want and then figure out the mapping implications.
(If you can't fill all 8 buttons then I can suggest 1&1/2 which most users will never hear by themselves but it sounds really funky)
A big help would be for you to post the mappings for every button you intend to use and the loop lengths you want for each button.
Button 1
button 2
Button 3
Button 4
geposted Sat 22 Nov 14 @ 12:11 pm
I would like to map1/2 beat, 1/4 beat , 1/8 , and 1/16 . kind of like on ddj sx or ns7two. for now i'm just using keyboard numbers |9|, |6|, |3|, |.| for the right deck and , |7|, |4|, |1|, |0| for left deck. thanks so much :) I've been meaning to do this for so long .
geposted Sun 23 Nov 14 @ 3:46 pm
this will do the left numbers as a trial if you want the scripts for the right, switch "deck left " to "deck right"
1/16
deck left effect_active 'loop roll' ? deck left effect_slider 'loop roll' 1 0.125 ? deck left effect_active 'loop roll' : deck left effect_slider 'loop roll' 1 0.125 : deck left effect_slider 'loop roll' 1 0.125 ? deck left effect_active 'loop roll' : deck left effect_slider 'loop roll' 1 0.125 & deck left effect_active 'loop roll'
1/8
deck left effect_active 'loop roll' ? deck left effect_slider 'loop roll' 1 0.25 ? deck left effect_active 'loop roll' : deck left effect_slider 'loop roll' 1 0.25 : deck left effect_slider 'loop roll' 1 0.25 ? deck left effect_active 'loop roll' : deck left effect_slider 'loop roll' 1 0.25 & deck left effect_active 'loop roll'
1/4
deck left effect_active 'loop roll' ? deck left effect_slider 'loop roll' 1 0.375 ? deck left effect_active 'loop roll' : deck left effect_slider 'loop roll' 1 0.375 : deck left effect_slider 'loop roll' 1 0.375 ? deck left effect_active 'loop roll' : deck left effect_slider 'loop roll' 1 0.375 & deck left effect_active 'loop roll'
1/2
deck left effect_active 'loop roll' ? deck left effect_slider 'loop roll' 1 0.5 ? deck left effect_active 'loop roll' : deck left effect_slider 'loop roll' 1 0.5 : deck left effect_slider 'loop roll' 1 0.5 ? deck left effect_active 'loop roll' : deck left effect_slider 'loop roll' 1 0.5 & deck left effect_active 'loop roll'
Next I'll need your mappers
1/16
1/8
1/4
1/2
geposted Sun 23 Nov 14 @ 11:55 pm
