Topic: History Time
Sent this to team and was advised to post here.
The history within VDJ 8 is off by 2 hours. That is when VDJ8 is open and you click history (far left)
it shows times played. This time is off by 2 hours, earlier than actually played.
When you check the history folder from VDJ documents, the time is correct.
Example one tune is played at 10:30 PM;
When you are in the program and check history, it appears as 8:30.
When you go to the VDJ documents history folder, it appears correctly [10:30]
Any ideas??
Now the crazy thing is that this weekend everything was fine.
geposted Mon 24 Nov 14 @ 10:09 am
Everything is displayed properly here in the history folder (correct played time). and i believe VirtualDJ simply uses your system clock.
System clock was correct.
Just a bit strange, as now it is back to normal.
I will just keep an eye one it.
Thanks
